Hamish Grundy Posted August 2, 2009 Share Posted August 2, 2009 my dad has a 300tdi discovery, n reg, he only bought it a few months ago, all was fine untill the other day the milometer stopped working, the total and the trip miles. but the speedo is fine, any ideas?? i do have another dash that i could try but id rather fix that as mine has done nearly 90k more than his! any suggestions would be helpfull. thanks, hamish Quote Link to comment Share on other sites More sharing options...
teabag Posted August 3, 2009 Share Posted August 3, 2009 If the reset button is pressed in and it stays in that will stop the numbers turning, other than that the drive cogs in the speedo head may be broken, detached. Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted August 3, 2009 Author Share Posted August 3, 2009 If the reset button is pressed in and it stays in that will stop the numbers turning, other than that the drive cogs in the speedo head may be broken, detached. ok il try that, thanks. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 4, 2009 Share Posted August 4, 2009 my old astra used to stick sometimes when it had to turn a lot of digits, ie if it was at 139999 it would jam and you could hear it clicking as you drove along. I found that hitting the dash, or forcibily pressing the reset button a few times would usually be enough to free it off. Quote Link to comment Share on other sites More sharing options...
