Briarston Posted August 13, 2009 Share Posted August 13, 2009 Hello all, I want to swap the grumbling front diff. on my "90". I have a good Disco diff. complete with drive shafts and cv. joints (ones with the integral stub shaft, into the drive member. Do I fit the whole lot, Disco diff. is 24 spline and I assume "90" diff. is 10 spline, or do I use my existing cv's with the Disco inner shafts? Are the splines into the cv's common to both shafts? Advice would be very welcome, thanks in advance! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 13, 2009 Share Posted August 13, 2009 I don't think the CV spines will be the same, so you'll have to swap the lot, which whilst you get stronger half shafts, you will get weaker CV's. I may be wrong, but a grown up will be along to correct me shortly. Quote Link to comment Share on other sites More sharing options...
