light upgrades
hi there , i have a early 90 and was wondering if any one has upgraded the front bulbs , looking for a bit more light up front . not looking for illegal fancy stuff , but bulbs that are fine with the autorities .
has any one changed theres ? was there much difference ?
cheers fraser
cheers fraser
"Da law" says you can't have a higher POWER bulb (more W's) the the manufacturer fits. What you can so (and I am about to do, and many others no doubt already have done) is to upgrade to +60% or +90% "Xenon" bulbs, which give more light than standard, but at the same wattage. More modern headlamp reflectors can also help, and all this assumes your not talking about sealed beam units :ph34r:
If you do go for better bulbs get ones with clear glass, as any coating
invariably acts as a filter and reduces light output.
I have these and am very happy with them.
They give a very white light compared to standard halogen bulbs.
You could also rewire the wiring using a relay and better wire directly
connected to the battery.
hi , cheers for the replies
looking for simple plug and play types , will be using the standard lenses / wiring . just need a bit more light than thats on the standard ones the now .
cheers fraser
