nickt Posted August 19, 2009 Share Posted August 19, 2009 I have been offered a tdi engine with a suspected head gasket fault my question is would this likely to be repairable as im aware some diesels would require a new head many thanks Quote Link to comment Share on other sites More sharing options...
white90 Posted August 19, 2009 Share Posted August 19, 2009 As long as it isn't expensive Headgaskets are common enough job on TDIs Quote Link to comment Share on other sites More sharing options...
nickt Posted August 19, 2009 Author Share Posted August 19, 2009 does that mean its likely to just be a gasket replacement rather than a lump of scrap Quote Link to comment Share on other sites More sharing options...
western Posted August 19, 2009 Share Posted August 19, 2009 be prepared to have the cylinder head skimmed too, just as a precaution in case it's not dead flat. Quote Link to comment Share on other sites More sharing options...
nickt Posted August 19, 2009 Author Share Posted August 19, 2009 sorry another stupid question im only used to petrol engines if i have a diesel head skimmed will i need a different size head gasket so not to change compression ratio Quote Link to comment Share on other sites More sharing options...
western Posted August 19, 2009 Share Posted August 19, 2009 sorry another stupid question im only used to petrol engines if i have a diesel head skimmed will i need a different size head gasket so not to change compression ratio the 200 & 300 Tdi's head gaskets go on the piston protrusion above the engine block face, the head gasket come in 4 thicknesses to suit the amount of protrusion measured, measuring piston protrusion on a 300Tdi done the same way on a 200Tdi engine & head gasket thickness is common to both engines. head gasket thickness info hope those help Quote Link to comment Share on other sites More sharing options...
nickt Posted August 19, 2009 Author Share Posted August 19, 2009 thanks for that chaps been big help Quote Link to comment Share on other sites More sharing options...
