Cartman Posted August 31, 2009 Share Posted August 31, 2009 Seeing as this is the Disco section of the forum I thought I should drift down here with the question? I am breaking a '93 Disco 1 and now need to pull both the gearbox and the 200tdi lump out. Access to the flywheel/bellhousing nuts looks like a PITA compared to a Series/Defender set-up so are there easy way's around it or should I just lop a hole in the tx tunnel? If anyone is interested the reast of the Disco is being broken down in the For Sales section here ---> http://forums.lr4x4.com/index.php?showtopic=46640 Paul Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 31, 2009 Share Posted August 31, 2009 No one will want the bodyshell. Cut the whole darn bulkhead off - including the tunnel. Decide if you you want to keep any of the other bits, if you don't then just grind or sabre saw your way in. G. Quote Link to comment Share on other sites More sharing options...
Cartman Posted August 31, 2009 Author Share Posted August 31, 2009 No one will want the bodyshell. Cut the whole darn bulkhead off - including the tunnel. Decide if you you want to keep any of the other bits, if you don't then just grind or sabre saw your way in. G. Shell will be weighed in along with the chassis and anything else no-one has a desire for The main bits someone 'may' want are the front and rear axles, long input shaft LT77 and Disco tx box. Chances are I will not be taking the diffs so they will be up for grabs to. I have an almost bottomless pit of 1mm chop disks for the 4" grinder so if needs must then Mr Happy Chopper will come-a-hacking Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted August 31, 2009 Share Posted August 31, 2009 Drop the gearbox x-member and then remove the engine mounts and g/box mounts with a jack underneath and lower it down slightly and it will be nice and easy to get at the bolts. Dave. Quote Link to comment Share on other sites More sharing options...
Cartman Posted August 31, 2009 Author Share Posted August 31, 2009 Cheers Dave and you are just down the road from me. Will give that a go in a few weeks once the other project vacates it's spot and the Disco and roll in Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted September 1, 2009 Share Posted September 1, 2009 Cheers Dave and you are just down the road from me. I didnt notice that Im just outside of salisbury in Porton. Dave. Quote Link to comment Share on other sites More sharing options...
Cartman Posted September 2, 2009 Author Share Posted September 2, 2009 I didnt notice that Im just outside of salisbury in Porton. Dave. Figheldean Quote Link to comment Share on other sites More sharing options...
