gazmc1973 Posted September 14, 2009 Share Posted September 14, 2009 Hi can any one help me my 91 disco v8 has a clunking noise when changing gear and pulling away (its a manual) its being doing this since i bought it a few months ago i had a look underneath while some one let cluth in and out and it doesnt clunk when not in gear but if select gear and let clutch out and hold on brakes it does and the clunk seems to come from the prop to front wheels where it enters the gear box area (forgive my terminolgy not a 4x4 expert) any help would be great ps props have been replaced before i got it Quote Link to comment Share on other sites More sharing options...
matt bristol Posted September 14, 2009 Share Posted September 14, 2009 Mine does the same (amongst other noises it makes), also when you put hte hand brake on and let your foot off the brake it rocks a bit so I assume its the transfer box is a bit worn or very worn. Quote Link to comment Share on other sites More sharing options...
teabag Posted September 15, 2009 Share Posted September 15, 2009 You could also check you propshafts uj's for wear. Quote Link to comment Share on other sites More sharing options...
gazmc1973 Posted September 15, 2009 Author Share Posted September 15, 2009 cheers ujs were changed so asume transfer box Quote Link to comment Share on other sites More sharing options...
saltyoldseadog Posted September 15, 2009 Share Posted September 15, 2009 This sounds like a routine Land Rover thing. Only (most) new ones don't clunk! If it gets bad it's worth getting the transfer box checked because you don't want to lose drive altogether. After 30 years of Land Rovers from Series 1 through to Range Rovers and now a '93 Disco 200Tdi I've got quite good at changing gear and letting in the clutch without causing a clunk. The only one I've owned that didn't clunk was an auto; they don't! Quote Link to comment Share on other sites More sharing options...
Discopoo Posted September 15, 2009 Share Posted September 15, 2009 Gotta agree, everyone one I have owned has done that, the latest one isn't so bad but has done less mile Quote Link to comment Share on other sites More sharing options...
chewy Posted September 15, 2009 Share Posted September 15, 2009 This sounds like a routine Land Rover thing. Only (most) new ones don't clunk! If it gets bad it's worth getting the transfer box checked because you don't want to lose drive altogether. After 30 years of Land Rovers from Series 1 through to Range Rovers and now a '93 Disco 200Tdi I've got quite good at changing gear and letting in the clutch without causing a clunk. The only one I've owned that didn't clunk was an auto; they don't! Mines the same, just let the clutch out gently and no clunk, got a funny noise coming from somewhere else though! Quote Link to comment Share on other sites More sharing options...
61a Posted September 16, 2009 Share Posted September 16, 2009 Does it judder when you pull away on low'ish revs? If it does check the bell housing is properly secure. I had a problem when I first got my 300 tdi and it turned out the previous owner had changed the clutch but not done the top bolts up enough, which then worked loose and cracked the bell housing !!! OUCH Been brilliant since I got it mended . Jules Quote Link to comment Share on other sites More sharing options...
gazmc1973 Posted September 17, 2009 Author Share Posted September 17, 2009 thank you all for help bell housing is fine 61a so ill just practice letting clutch out slow Quote Link to comment Share on other sites More sharing options...
herdwick. Posted September 17, 2009 Share Posted September 17, 2009 had the same problem,after a few months of "practising" out it turned out it was a worn output gear/flange, it's the flange that takes the drive from the gearbox main shaft into the transferbox(correct me if i named wrong any parts) some times a worn main shaft means a lot of labour to fix it. Quote Link to comment Share on other sites More sharing options...
