santalars Posted September 15, 2009 Share Posted September 15, 2009 I have an occasional power loss problem and any opinions would be appreciated: Every now and then there is s significant loss of power during long journeys. When gearing down and reving high there are puffs of black smoke (more than ususal). Yesterday I stopped and wanted to examine further. I found that the engine is running ok on tick over, but when reving slightly higher (approx 200 to 300 rpm more) the engine is running very rough with bad vibrations and grey smoke when pushing the pedal down. It's feeling like it's running on 3 cylinders only. (I think that rules out the turbo hose option)The engine appears to run smoother on higher revs. After 10 to 20 miles driving the problem dissapears. I know that my injection pump won't last forever as I have the odd metal powder on the cut off solenoid, but the performance is ok so far (appart from the weak moments) As this is strangely a self curing problem I thought the following: Some of the metal powder gets to the injectors, blocking one of them occasionally (or keeping it open). The perssure then cleans it out after a while and it's running fine then. So: replace injection pump and injectors?????????? Anything I am missing anything, not understanding it, or any other suggestions? Many thanks Quote Link to comment Share on other sites More sharing options...
errol209 Posted September 15, 2009 Share Posted September 15, 2009 I know that my injection pump Right, we know it's a diesel, but which one? 2.5NA, 2.5TD, 200TDI, 300TDI, TD5, 2.4, or other? Quote Link to comment Share on other sites More sharing options...
santalars Posted September 15, 2009 Author Share Posted September 15, 2009 Sorry, 300tdi, 1996 Quote Link to comment Share on other sites More sharing options...
trickydicky Posted September 15, 2009 Share Posted September 15, 2009 Sorry, 300tdi, 1996 its just a thought have you tryed opening your air filter box and driving it then? i had simular symptoms and it turned out to be a flattened air intake in the wing Quote Link to comment Share on other sites More sharing options...
santalars Posted September 19, 2009 Author Share Posted September 19, 2009 The air supply is all fine. Had a cloder look and I'm sure that one injector is dull. Have to drive 500 miles before I have a chance to fix it. Will this be anyhow bad for the engine? Quote Link to comment Share on other sites More sharing options...
