silversurfer Posted September 22, 2009 Share Posted September 22, 2009 P38 rear wiper not working. I have over 10 Volts coming through the orange wire, Nothing at all coming through the orange & black. If I plug the main feed back into the motor then disconnect the last plug in the loom (Blue & Black wire small plug) no power coming through at all? Then to confuse matters even more a direct feed from the battery bypassing wiring loom everything works fine. Any ideas?? Thanks. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted September 24, 2009 Share Posted September 24, 2009 Sounds like you're going to have to trace the wiring back until you find where the circuit is broken Could be a connector come apart or just too dirty to make contact, broken wire (no necessarily visible, could be a broken core with the sheath intact) or a short to ground (probably where the wire has been pinched or rubbed on metalwork). Download the Rave (workshop) manual form the Green Oval website and have a look at the wiring diagrams - they aren't great, but will at least show you where the loom runs. Let us know how you get on Quote Link to comment Share on other sites More sharing options...
