disco axle "will it fit"
dicsosfa
hi :)
just want to know if a complete front axle from a L reg 300 tdi disco will fit a M reg one as one of my swivals is knackered and have been offered it for 50 notes both have anti roll bars fitted and as this is a bit cheaper than swival kits
Roy ;)
yep, nearly all coil land rovers axles are interchangeable, even if one is 12 spline and the other is 24 spline they all have the same ratios and they all have the same spring layouts etc, exept maybe the 110 HD and 130 rear alxes as the springs are a different diameter. it should be a straight swap, the only complications i could think of would be ABS and TC if you have them and tey are not compatible with the axle, but if you keep the origional calipers it should sort that problem.
mikey
