Turning off blower motor??
silversurfer
Hi, I suspect there may be a fault on the switch as mine turns the blower off completely when I turn the switch all the way to the left. Or it could just be a dirty contact. Is the book symbol lit on the heater display?
Sorry I can't be of more help.
There is no specific 'Off' switch for the blowers, only the rotary control, any output of which is controlled by the HEVAC ECU, of which the control switches + display are part.
If you really want the blowers totally disconnected, look for the appropriate relays or fuses in the engine bay fuse box. There is a pictogram inside the fuse box lid to help.
I cannot recall if mine can be switched off via the rotary switch; it's not something I'd bother with, but I recognise you are handling some other A/C fault at the same time.
Again, The ETM (Electrical Troubleshooting Manual) that comes as part of a RAVE CD is invaluable.
There are words describing the circuit operation, as well as wiring diagrams, etc.
HTH
