andrew69 Posted October 10, 2009 Share Posted October 10, 2009 hello. i am wondering can you purchase modular wheels for series 2a 109.i see the holes in pictues not sure they will fit. cheers. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted October 11, 2009 Share Posted October 11, 2009 hello. i am wondering can you purchase modular wheels for series 2a 109.i see the holes in pictues not sure they will fit. cheers. You can, but you'd be well advised to change the hubs to series 3 as the wheel studs and nuts are larger. G. Quote Link to comment Share on other sites More sharing options...
andrew69 Posted October 12, 2009 Author Share Posted October 12, 2009 You can, but you'd be well advised to change the hubs to series 3 as the wheel studs and nuts are larger. G. thanks, is changing the hubs easily done and is it doable by a no.vice Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 14, 2009 Share Posted October 14, 2009 you only need socket sets and a hub nut spanner, plus a BIG mscrewdriver to take the retaining screw out the brake drum Quote Link to comment Share on other sites More sharing options...
