mad_pete Posted October 15, 2009 Share Posted October 15, 2009 All, Had some front pipes replaced on my 94 classic. Now when the brake pedal is pushed the brakes come on lightly then there is a slight 'bounce' from the pedal and the brakes come on harder. It's like the some sort of brake assist is lagging to come on. I have full brake power after the bounce. So Is that normal ? Will it settle down after a while ? Do I need to replace expensive bits ? Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 24, 2009 Share Posted October 24, 2009 Have you followed the correct bleeding sequence? The power brake system on these needs bleeding, by following the landrover procedure TO THE LETTER!!!! No other way of doing it will work properly. Jon Quote Link to comment Share on other sites More sharing options...
