Dowty Hydraulic Pump.
David Sparkes
I've got a Dowty pump attached to a Series gearbox PTO.
The pump has some numbers and letters on the cover containing the Dowty name, but I can't resolve them to throughput etc.
Does anyone here have the Dowty knowledge?
The markings below the Dowty name are 33 77 4. I feel this may be the Serial Number, although I reproduced the spacing here, it may be inadvertent, so perhaps should be seen as 33774.
The markings above the Dowty name are 7702 1P 3060 AF. The spacing and grouping on the end plate appears definite.
The end plate is held on with 4 bolts.
Regards,
