ROGUE TROOPER Posted April 17, 2006 Share Posted April 17, 2006 Which one of these from the Dizzy Amplifier (Flapper 3.5 v8) is the + and which is the - ? Many thanks Quote Link to comment Share on other sites More sharing options...
white90 Posted April 17, 2006 Share Posted April 17, 2006 stick a meter across one at a time to the engine block/water pump housing the one that shows short cct is the earth I'd say Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted April 17, 2006 Author Share Posted April 17, 2006 Thanks but they both give readings........ Strange as they show a circuit then when you go back to then they dont! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 17, 2006 Share Posted April 17, 2006 Rogue, I had this prob on the hybrid,m the factory replacement wires were the same colour but wired in reverse, when conected up it ran but horribly, switched them around at the plug end and it was then fine.. This is a way out your prob, wire it up, only one way works ! Nige Quote Link to comment Share on other sites More sharing options...
