AndyO Posted December 15, 2009 Share Posted December 15, 2009 Hi All, Driving along this morning my dash lights for 'ABS' 'TC' & the hill descent with exclamation mark illuminated and stayed lit. Does anyone know what this means? and what the problem might be? Ta Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted December 15, 2009 Share Posted December 15, 2009 I would suggest doing a search for 'three amigos' as it will bring up some useful information. Pete. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted December 15, 2009 Share Posted December 15, 2009 Agree...........there is quite a few things that will put all 3 lights on......diagnostic's is the quickest way to find out. Post your location and there maybe someone close by that can help. Quote Link to comment Share on other sites More sharing options...
vinck Posted December 19, 2009 Share Posted December 19, 2009 Hi All, Driving along this morning my dash lights for 'ABS' 'TC' & the hill descent with exclamation mark illuminated and stayed lit. Does anyone know what this means? and what the problem might be? Ta I puchased an "abs amigo" from www.RSWsolutions.com in the usa. This is a diagnostic as well as a repair tool for the three on coming lights (abs, tc and hdc). You just plug it in the obd and you get a reading + a repair. Whe connecting it to uour pc you can get a read-out of the logged errors in the system. I'm very pleased with it, and it enabled me to trace the souce of my problems: the front right ABS sensor im my disco 2. this is an example of the read-out: -------------------------------------------------------------- |* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *| |* www.RSWsolutions.com *| |* *| |* *| |* Version V1.1 *| |* *| -------------------------------------------------------------- 1.--Current Faults----> Active Faults: None Logged Faults: Front Right Sensor Bad Output <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ ..--Previous Faults---> Active Faults: None Logged Faults: 044:Front Right sensor output low 064:Front Right sensor electric fail Front Right Sensor Bad Output <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ ..--Previous Faults---> Active Faults: 022:ECU Gnd or Reference Gnd bad 064:Front Right sensor electric fail 065:Rear Left sensor electric fail 066:Front Left sensor electric fail 067:Rear Right sensor electric fail Logged Faults: None <-END Faults ------------------------------------------------------------ * Quote Link to comment Share on other sites More sharing options...
