maigaard Posted December 18, 2009 Share Posted December 18, 2009 Hi, I am fitting an ARB (RD127) to a 1986 RRC V8 EFI and have run into trouble. I've built the diff and fitted the diff to the axle. But when fitting the drive shafts, the RH shaft (the short one) is slightly too long (or the splined area of the shaft is too short). I've got the solid drive shafts (no separate drive flange), part # 571882. I also happen to have a similar drive shaft from a 1990 RRC (part # FTC870) in the workshop, which a bit shorter and the splined area is longer. That may fit, but has a bulge on the axle, so it cant be slid into the axle housing. Is it so that the 10 spline ARB is only made to fit FTC870 drive shafts, and not 571882 ? Any tips how to proceed ? Thanks, Peter Quote Link to comment Share on other sites More sharing options...
maigaard Posted December 19, 2009 Author Share Posted December 19, 2009 that's the rear axle of course, in case that wasnt clear from the prev. post /Peter Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 19, 2009 Share Posted December 19, 2009 Looks as if you have bought an ARB Plus Shafts ? If so then there are 2 lengths of shafts for RR rear axles, early (long) often called Imperial, and the later shorter "Metric" axle, looks tho you have a miss match Nige Quote Link to comment Share on other sites More sharing options...
maigaard Posted December 19, 2009 Author Share Posted December 19, 2009 Hi, thanks for the tip on imp/metric. I bought the ARB RD127 and metric bearings for it. Didnt purchase shafts, I am trying to use the original shafts from the 1986 RRC. The funny thing is that the LH side is OK. Fixed the RH side for now by extending the splined section about half a cm with an angle grinder. There's so much snow here now, I just needed to get it running and go play :-) When the snow is gone I might try to transplant all the outer axle parts (hub, stub axle etc) over from the 1990 RRC axle I have also, which has the slightly shorter shafts with separate drive flange. /Peter Quote Link to comment Share on other sites More sharing options...
