Aragorn Posted January 18, 2010 Share Posted January 18, 2010 While procrastinating here at work i'm trying to find out some info on the TD5 speedo transducer. Does anyone know what kinda output it gives? I.E. 8 pulses per revolution, 0v reference point with 12v spikes? How does it compare to the Disco 300TDi/TD5 sender? Cheers Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted January 18, 2010 Share Posted January 18, 2010 This is from Rave: The speed transducer (C0195) provides a square wave, pulsed speed signal to the instrument pack (C1060) on a BR wire. The instrument pack uses this signal to drive the speedometer. The speedometer also doubles the frequency of pulses (from 4100 per mile to 8200 per mile) and provides an output to the ECM (C0658 – Td5 vehicles only) and the overspeed ECU (C1311 – Gulf specification vehicles only) on YK wires. It might help. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted January 18, 2010 Author Share Posted January 18, 2010 Oooh thats perfect. The Audi ECU as standard appears to run on a signal of around 6500pulses per mile, so looking at that, hopefully if i simply take the output to the ECM and feed it into the Audi ECU it will work, albeit with a 20% overspeed, hopefully the ECU wont mind too much. Cheers Quote Link to comment Share on other sites More sharing options...
