series 2 petrol . 2nd gear crunch
muddy4x4xfar
  • 3 weeks later...
hi iv been offered a series2 in brilliant condition all except the gear box crunches when going into 2nd. he says its easy to fix just wanted to know what the profesionals have to say?
cheers everyone.
chris
Like they say, you'll get used to it. They aren't like driving a modern car.
Don't rush second gear, just apply a little pressure & let it 'drop' in on it's own. It will help if you don't take the revs up too high in first. Or..... just pull away in second. :P
Chris, do you know if it jumps out of gear at all in second or third? If it doesn't, then its probably OK and the crunch is just down to lack of syncromesh on 1st & 2nd gear which is correct for that 'box.
If it jumps out of gear on overrun (when engine braking) then its probably got problems with the layshaft.
Steve.
