ajh Posted February 6, 2010 Share Posted February 6, 2010 So... if new bearings are not available to fix a steering column, why does the Def_90_110_WSM_book4.pdf on page 57 have a maintenance procedure that requires removing the old bearings and fitting new ones? Quote Link to comment Share on other sites More sharing options...
RTF Posted February 6, 2010 Share Posted February 6, 2010 I presume you mean the one at the bottom end of the column had that problem 5 year`s ago asked about the part with no sucess so got a bronze bush made to fit in instead also drilled a small hole in the column housing so can put a little oil in when I remamber Good luck in trying to get a bearing Quote Link to comment Share on other sites More sharing options...
western Posted February 6, 2010 Share Posted February 6, 2010 actually on Section 57 pages 5. probably not in the parts book, because full workshop facilities are required to remove/fit the column bearings, don't forget the genuine workshop manual was meant for main dealers staff only not meant for genral public release. Quote Link to comment Share on other sites More sharing options...
