Pete Boy Posted February 9, 2010 Share Posted February 9, 2010 Hello there I have a 1986 110 with a 200 tdi engine fitted.I have changed the fuel tank and re fitted the fuel pick up pipe and sender unit back into the tank,and reconnected the two wires. There is a threaded rod on the sender,is this an earth? There was nothing attatched at time of removal.I have three wires,two are colour coded to the tank sender,is the third wire an earth? With the ignition turned on,the live wire is showing six volts only.Is this correct? Any help most appreciated Pete Quote Link to comment Share on other sites More sharing options...
western Posted February 9, 2010 Share Posted February 9, 2010 There is a threaded rod on the sender,is this an earth? There was nothing attatched at time of removal.I have three wires,two are colour coded to the tank sender,is the third wire an earth? threaded rod is the sender unit Earth connection, there should be a Black wire with a circular push on terminal [looks a bit like a female bullet connector the other 2 are for the gauge & low fuel warning light. Quote Link to comment Share on other sites More sharing options...
Pete Boy Posted February 9, 2010 Author Share Posted February 9, 2010 threaded rod is the sender unit Earth connection, there should be a Black wire with a circular push on terminal [looks a bit like a female bullet connector the other 2 are for the gauge & low fuel warning light. Thanks,ill get the earth back and go from there. Cheers Pete Quote Link to comment Share on other sites More sharing options...
