Series thermostat temperature
marysboy
Hello all,
The thermostat on my Series 3 is open all the time and I need a replacement. I see that there are two versions available:
Part number 532453 = 74 degrees C
Part number 596225 = 82 degrees C
I'm not sure which I should have, does anyone here know? I have a 1977 2.25 diesel.
Thanks all,
Ian.
  • 2 months later...
Well I've had my 82deg thermostat in for a couple of months now. Rather than never reaching operating temperature, the engine now heats up in 5 minutes. The heater blows warm air (shock!) and the engine is more lively. The temperature sits just below the red line all the time - will see how summer affects that!
Ian.
Ian.
I was going to suggest the 82oC one for just those reasons. The 74 is mainly for the MoD fleets, and primarily for FFRs that spend a lot of time idling. they use the lower setting so that the flow keeps the temperature from peaking.
Good info, thanks :)
