craig Posted February 16, 2010 Share Posted February 16, 2010 just got an n reg 300tdi discovery es, everything is electric which as im finding out aint gonna be fun!! anyway the electric seats are faulty, the drivers will only move in one direction , because of this i know they getting power. is it generally the switch units? can they be fixed? or bodged???? cheers craig Quote Link to comment Share on other sites More sharing options...
karlo Posted February 16, 2010 Share Posted February 16, 2010 just got an n reg 300tdi discovery es, everything is electric which as im finding out aint gonna be fun!! anyway the electric seats are faulty, the drivers will only move in one direction , because of this i know they getting power. is it generally the switch units? can they be fixed? or bodged???? cheers craig Yes you can strip the switches, clean them and rebuild them a bit fiddly but can be done. lots of ball bearings and springs. Quote Link to comment Share on other sites More sharing options...
craig Posted February 16, 2010 Author Share Posted February 16, 2010 does this usually cure it? ill have a go at stripping the switches........ Quote Link to comment Share on other sites More sharing options...
MrKev Posted February 17, 2010 Share Posted February 17, 2010 yes, there is a short guide here: http://forums.lr4x4.com/index.php?showtopic=47674 Kev Quote Link to comment Share on other sites More sharing options...
dave t Posted February 17, 2010 Share Posted February 17, 2010 does this usually cure it? ill have a go at stripping the switches........ before you do try spraying a bit of contact cleaner in the switch. I had this problem with the switches on my RRC and just spraying the cleaner fixed the problem and saved me a fiddley job!! Quote Link to comment Share on other sites More sharing options...
