electric seats
craig
just got an n reg 300tdi discovery es, everything is electric which as im finding out aint gonna be fun!!
anyway the electric seats are faulty, the drivers will only move in one direction , because of this i know they getting power. is it generally the switch units? can they be fixed? or bodged????
cheers
craig
cheers
craig
Yes you can strip the switches, clean them and rebuild them a bit fiddly but can be done. lots of ball bearings and springs.
does this usually cure it?
ill have a go at stripping the switches........
before you do try spraying a bit of contact cleaner in the switch. I had this problem with the switches on my RRC and just spraying the cleaner fixed the problem and saved me a fiddley job!!
