Michele Posted August 24, 2005 Share Posted August 24, 2005 Trying to relax with less dangerous issues... Made my own additional dashboard for in-cab lockers & winch controls, and also added the ARB compressor switch,which doesn't illuminate actually... Instructions say "to dash illumination" at a certain point,where did you (who have it) take the source/run the cable? I'm not very smart in interpreting electrical diagrams and so on...! Ta! Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 24, 2005 Share Posted August 24, 2005 theres normally 2 illuminations on them IIRC. illuminated when u swithc your lights on and bigger (for the use of a better word) when switched in use, if that makes sense Quote Link to comment Share on other sites More sharing options...
Michele Posted August 24, 2005 Author Share Posted August 24, 2005 So I suppose the 1st goes in when you flick your position lights;where do I link it to? Main light switch? Or...? Quote Link to comment Share on other sites More sharing options...
Ivan Posted August 24, 2005 Share Posted August 24, 2005 Michele To illuminate the switch when the side lights are on you need a feed from the instrument lights. This is usually a red wire with a white tracer. So just find one of these on the instrument panel and join a cable to it. To illumintae the switch when activated take a feed from the output side of theswitch (the bit that activates the lockers) and connect it to the relevant terminal. HTH Ivan Quote Link to comment Share on other sites More sharing options...
Michele Posted August 31, 2005 Author Share Posted August 31, 2005 It seems like I missed some replies in the last weeks. Thanks Ivan,I'll try ASAP and let you know. Can't wait to have some new lights in the cab! Quote Link to comment Share on other sites More sharing options...
