Niamh Posted March 26, 2010 Share Posted March 26, 2010 Should there be any rotational play in a CV joint? I never recall seeing any before, however this RH CV joint has quite a bit and I'm wondering if that's the source of the vibration under power. I don't really want to go to the trouble of pulling the other CV joint to compare unless I have to. RHD 300TDi non-ABS Niamh Quote Link to comment Share on other sites More sharing options...
disco_al Posted March 26, 2010 Share Posted March 26, 2010 check your prop u/j's and the rear doughnut - i had a vibration under power and it turned out to be the rear prop coupling falling apart Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 26, 2010 Author Share Posted March 26, 2010 Both seem OK. Though I'm not going to put the CV joint back in until I get a view on whether it's OK or not. Axial play seems OK and is mostly at the circlip so it seems Niamh Quote Link to comment Share on other sites More sharing options...
Fantic Posted March 27, 2010 Share Posted March 27, 2010 Last CV joint in my Disco had no rotational play at all. Did it click or tap on full lock? Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 28, 2010 Author Share Posted March 28, 2010 No click on full lock... but with 235/85s full lock isn't what it used to be. Given the cost I think it's worth replacing anyway. Niamh Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 28, 2010 Author Share Posted March 28, 2010 Just stripped it off the 1/2 shaft and most of the play is in the splines between 1/2 shaft & CV joint. Niamh Quote Link to comment Share on other sites More sharing options...
Fantic Posted March 28, 2010 Share Posted March 28, 2010 That could easily be a source of the vibration then .. and any other connections in the drive train with even minimal play in them will only add to it .. Quote Link to comment Share on other sites More sharing options...
picpoki Posted March 28, 2010 Share Posted March 28, 2010 I have a lot of free play in my defender to. If I jacke one wheel and try to turn it it has 1/5 of turn of free play. So this would be the splines fault? Cheers D. Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 28, 2010 Author Share Posted March 28, 2010 72 degrees of play! Niamh Quote Link to comment Share on other sites More sharing options...
Fantic Posted March 28, 2010 Share Posted March 28, 2010 I have a lot of free play in my defender to. If I jacke one wheel and try to turn it it has 1/5 of turn of free play. So this would be the splines fault? Cheers D. Not necessarily all down to splines .. play at the wheel is from cvjoint, halfshaft, diff pinion/crown, UJ's, transfer input, transfer to gearbox etc ... more than one connection, and all wear eventually! Quote Link to comment Share on other sites More sharing options...
picpoki Posted March 28, 2010 Share Posted March 28, 2010 That`s quite a lot, right? I just got reconditioned gearbox and got a new input gear and I don`t want to change the hole thing again after 2 years. Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 28, 2010 Author Share Posted March 28, 2010 If you've got that must play then if it is splines then you have practically none left... FWIW it takes about 15 mins to pull a 1/2 shaft and CV joint to check. Niamh Quote Link to comment Share on other sites More sharing options...
picpoki Posted March 28, 2010 Share Posted March 28, 2010 So I have to change halfshaft and CV joint? What about the diferential splines? Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 29, 2010 Author Share Posted March 29, 2010 Only if they're knackered. Niamh Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 31, 2010 Author Share Posted March 31, 2010 OK, replacement 1/2 shat an CV joint arrived yesterday and there is no rotational play... Now just need to wait for it to stop pissing down to do the refitting. Niamh Quote Link to comment Share on other sites More sharing options...
Fantic Posted March 31, 2010 Share Posted March 31, 2010 OK, replacement 1/2 shat an CV joint arrived yesterday and there is no rotational play... Now just need to wait for it to stop pissing down to do the refitting. Niamh Nice one ... I use a gazebo sometimes ... Quote Link to comment Share on other sites More sharing options...
