2drdan Posted May 11, 2006 Share Posted May 11, 2006 Arctic heater needs a home, cluttering up garage and I've had a RR for a few years now so no use to me anymore!! The front plate has had the pipe connections turned around to fit it behind the bulkhead (S11A SWB) but otherwise std. in reasonable nick with all pipes (i think) and block connector/tap/themostat housing/window vents/etc. Pics can be e-mailed. Quote Link to comment Share on other sites More sharing options...
dasterdly Posted May 11, 2006 Share Posted May 11, 2006 Arctic heater needs a home, cluttering up garage and I've had a RR for a few years now so no use to me anymore!!The front plate has had the pipe connections turned around to fit it behind the bulkhead (S11A SWB) but otherwise std. in reasonable nick with all pipes (i think) and block connector/tap/themostat housing/window vents/etc. Pics can be e-mailed. evening, how much do you want for the heater, pics please. cheers... Quote Link to comment Share on other sites More sharing options...
2drdan Posted May 11, 2006 Author Share Posted May 11, 2006 £70 or there abouts pics coming, dial up waaaaay slow, will be links to them, Ta. Quote Link to comment Share on other sites More sharing options...
2drdan Posted May 11, 2006 Author Share Posted May 11, 2006 Hopefully these'll work.....? http://i83.photobucket.com/albums/j297/2dr...Arcticpipes.jpg http://i83.photobucket.com/albums/j297/2dr...Arcticheat2.jpg http://i83.photobucket.com/albums/j297/2dr...rcticblower.jpg http://i83.photobucket.com/albums/j297/2dr...Arcairpipes.jpg Cheers. Quote Link to comment Share on other sites More sharing options...
dasterdly Posted May 12, 2006 Share Posted May 12, 2006 Hopefully these'll work.....?http://i83.photobucket.com/albums/j297/2dr...Arcticpipes.jpg http://i83.photobucket.com/albums/j297/2dr...Arcticheat2.jpg http://i83.photobucket.com/albums/j297/2dr...rcticblower.jpg http://i83.photobucket.com/albums/j297/2dr...Arcairpipes.jpg Cheers. evening, having looked at the pics, the articblower is very,very similair to the rack blowers we fit in our coaches, and the arcticheat is nearly the same as the coach heaters ! so i bet you can guess where i am going this this line of thinking.... :-) thank you for the pictures, i can feel some fabrication coming up.. cheers... Quote Link to comment Share on other sites More sharing options...
2drdan Posted May 14, 2006 Author Share Posted May 14, 2006 evening, having looked at the pics, the articblower is very,very similair to the rack blowers we fit in our coaches, and the arcticheat is nearly the same as the coach heaters ! so i bet you can guess where i am going this this line of thinking.... :-)thank you for the pictures, i can feel some fabrication coming up.. cheers... No worries, it'll get a home i'm sure! FYI the block connector is a std BSP (?) fitting 11/4".........need to check that but definately thereabouts, can be bought at plumb merchants i guess....still it is 4 in the morning (maybe zoom the photo?) Cheers. Quote Link to comment Share on other sites More sharing options...
David V Posted September 27, 2006 Share Posted September 27, 2006 Arctic heater needs a home, cluttering up garage and I've had a RR for a few years now so no use to me anymore!!The front plate has had the pipe connections turned around to fit it behind the bulkhead (S11A SWB) but otherwise std. in reasonable nick with all pipes (i think) and block connector/tap/themostat housing/window vents/etc. Pics can be e-mailed. Is the Arctic heater still available? 70 pounds right? I'll be in the UK from Monday next on (Oct 2nd) so if it's available I'll give you a call and arrange something. One question. 12v or 24? I want to fit one to my '79 FFR 24vdc Lighweight on the bulkhead behind the front seats. David Vervaet (West coast Canada) Quote Link to comment Share on other sites More sharing options...
