dailysleaze Posted May 1, 2010 Share Posted May 1, 2010 Hopefully quick and easy. When the rocker arm is pushed up by the valve to its natural gap, I can then push the rocker arm further down onto the push rod and open the gap considerably. Should I set the clearance at the height the valve sets the arm to, or should I adjust the rocker arm so that the maximum rocking movement between the top of the push rod and the valve cap is .2mm? Cheers. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2010 Share Posted May 1, 2010 If the other valve for the same cylinder is compressed, then the gap will be at it's maximum and can then be set. Les. Quote Link to comment Share on other sites More sharing options...
