M&S Posted May 11, 2010 Share Posted May 11, 2010 Hi all, Found out what my "clunk" is. The front diff has properly given up, making a rattling and leaking oil and, I suspect, causing the sudden unbalance I now have. Anyway, I'm skint so want to do this job as cheaply as possible. I can get a used front diff cheaply, so labour will be the largest part. I'm sure I am capable of doing it myself but I can't find any guides as to how. Even the Haynes manual doesn't cover it I've done a search, but can't find anything on the forum so...does anyone have a link please? Thanks, Martin Quote Link to comment Share on other sites More sharing options...
ches Posted May 11, 2010 Share Posted May 11, 2010 it's in Rave looks easy enough. Quote Link to comment Share on other sites More sharing options...
M&S Posted May 11, 2010 Author Share Posted May 11, 2010 Do I need to strip the hubs etc, or can I just remove the bolts and track rod/drag link and pull the hubs away a bit? Quote Link to comment Share on other sites More sharing options...
Andy Posted May 11, 2010 Share Posted May 11, 2010 Just pull the hubs out if its the same as earlier axles. A couple of inches should clear the diff. Quote Link to comment Share on other sites More sharing options...
M&S Posted May 12, 2010 Author Share Posted May 12, 2010 It isn't the same as earlier axles, but it might be as far as changing the diff goes If someone can confirm this that would be a big help. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted May 12, 2010 Share Posted May 12, 2010 Very easy - undo the calipers and move them out of the way. undo the (i think it's 4 from memory - maybe different) hub bolts and pull the hub assembly and cv/halfshaft out, job done. don't forget the track rod. Steve Quote Link to comment Share on other sites More sharing options...
M&S Posted May 12, 2010 Author Share Posted May 12, 2010 Very easy - undo the calipers and move them out of the way. undo the (i think it's 4 from memory - maybe different) hub bolts and pull the hub assembly and cv/halfshaft out, job done. don't forget the track rod. Steve Magic, just what I hoped! Thanks Steve! Second hand diff bought for £50, replace it myself, new oil, some black sealant and job should be a good'un. I'd rather do it myself as I think I may be doing quite a few of these Quote Link to comment Share on other sites More sharing options...
M&S Posted May 13, 2010 Author Share Posted May 13, 2010 Second hand diff arrived in MINT condition, if the casing had been painted I'd have thought it was new! A bargain for £50 The job went well, the only sticking point is the track rod end. The nut picked up on the way off Ended up grinding it off so I could put it in the vice and change the end...yeah, right! Who'd have thought out of the whole job the thing that's stopping me driving it is a bloody track rod end A mates taking it to a garage tomorrow, so hopefully it'll come back with a new end Anyway, happy I can change a front diff now, looking forward to the test drive tomorrow afternoon... Also looking forward to rebuilding my old diff as it doesn't look unrepairable. Bearings are gone and the planet gears, pin and carrier hare damaged, but apart from that Thanks again Steve. Quote Link to comment Share on other sites More sharing options...
M&S Posted May 14, 2010 Author Share Posted May 14, 2010 The non-adjusting end of the track rod doesn't come out, it's pressed in and a new rod is required Anyway, job done, test drive, and I'm over the moon! The truck is so smooth, no noises, no clunks, it's sweet! The new diff is spot-on Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted May 14, 2010 Share Posted May 14, 2010 Glad it went well for you, if you need any help/advise when you come to re-build your knackered diff then just shout, a re-build doesn't need to be costly! Steve Quote Link to comment Share on other sites More sharing options...
M&S Posted May 14, 2010 Author Share Posted May 14, 2010 Well now you come to mention it... Thanks Steve, I shall strip mine down and take some pics of the bits I need. I've asked a couple of local 4x4 garages but they don't seem to know the part numbers or be able to get the parts It'll be new bearings and oil seal (I know I can get those locally), planet gears and pin. The carrier (the centre casting that the pin sits in) is ovalled where the pin sits. I was thinking of oversizing the hole and fitting a sleeve perhaps? The ring and pinion are as new and the rest all looks good If you have a parts list/price list available please feel free to send me it. It will be a few weeks before I can afford to overhaul the old diff, hopefully I won't need it before then! Thanks, Martin Quote Link to comment Share on other sites More sharing options...
