del Posted May 15, 2010 Share Posted May 15, 2010 Hi all got a bit of a leak on my 90, it seems to be coming from the the clutch pipe namely the solid pipe union were it joins into the flexable rubber (were its fixed to the bulkhead) ,is this a seal thats failed ,dont seem to be loosing loads of fluid from the resevoir but enough to leave a nice damp patch on the road. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 15, 2010 Share Posted May 15, 2010 No seal at that point - the pipe has a 'mushroom end', similar to brake pipe ends. The end of the flexi pipe is shaped so that when the two are screwed together there is a tight seal. Les. Quote Link to comment Share on other sites More sharing options...
del Posted May 15, 2010 Author Share Posted May 15, 2010 I gave it a tweek , i think its the slave cylinder the unions not leaking something underneath is! , how much would a garage charge to fit a slave cylinder? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 15, 2010 Share Posted May 15, 2010 You can do it yourself for free, doesn't get any cheaper than that Change the clutch master cylinder at the same time as it won't last long with a new slave at the other end. Have a look here HTH Mo Quote Link to comment Share on other sites More sharing options...
