Prith Posted May 18, 2010 Share Posted May 18, 2010 My Defender 110, 200tdi glow plug heater relay is malfunctioning. Can some one please give me the part number for the relay & also the part number for the reverse switch on the Transfer box/ gear box. Its a Def 200tdi with a LT77 & LT230. Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 18, 2010 Share Posted May 18, 2010 Did you fit the relay when you did the conversion? I left it off of mine when i converted the TD to tdi and just ran the glow plugs off of the key like on the old system. Quote Link to comment Share on other sites More sharing options...
Prith Posted May 18, 2010 Author Share Posted May 18, 2010 Did you fit the relay when you did the conversion? I left it off of mine when i converted the TD to tdi and just ran the glow plugs off of the key like on the old system. Yes! Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 18, 2010 Share Posted May 18, 2010 In that case, i'd convert it back to the old system and forget about the relay! Cheaper and less to go wrong and unless it is very cold, the glow plugs probably arent needed at all on the 200tdi. Here is a link to the relay i think (double check this one as there is not much info on the link): http://www.lrseries.com/shop/product/listing/13597/YWB100560L-RELAY-70-AMP-GLOW-PLUG.html?search=glow plug relay&page=1 or try here: http://www.land-rover-parts-shop.com/shop/lrps/en/browse/Defender+110/2/0/21/84/305 and reverse switch http://www.lrseries.com/shop/product/listing/10001/PRC8204-SWITCH-REVERSE-LAMP.html?search=reverse switch lt77&page=1 Quote Link to comment Share on other sites More sharing options...
Prith Posted May 18, 2010 Author Share Posted May 18, 2010 thanks very much again Quote Link to comment Share on other sites More sharing options...
