Gromit Posted May 20, 2010 Share Posted May 20, 2010 Hi All, My new '05 TD5 110 has failed its test and I've a few small things to put right. Could someone confirm some part numbers? I've yet to get RAVE working, so have been looking on lrseries etc. Front radius arms - bushes x4 - from radius arm to axle. Are they NTC6860? The rear shocks are not original, think they are monroes ( I don't have the truck beside me at the moment) I'm looking for lower bush that does below the axle bracket. Is it RNF100090L? Finally, There's some play in one of the wheel bearings. I've tightented wheel bearings on my 200tdi before, but does the TD5 have a different arrangement? I seem to remember something about there now being one staked but instead of 2 nuts/locking tab. If so, can you revert to the old type? Can anyone enlighten me before I pull the flange. Many thanks! Quote Link to comment Share on other sites More sharing options...
western Posted May 20, 2010 Share Posted May 20, 2010 first you need Microcat for Parts not RAVE Radius arm to axle bush = NTC6781 rear damper lower bush = Is it RNF100090L ? Yes wheel bearing adjustment nut you can change to the earlier 2 nuts & lock washer system, as your 200TDi had fitted. Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 21, 2010 Author Share Posted May 21, 2010 Thanks for the info Ralph. Feel a bit lost without a parts cat at the moment. Have ordered some hub locking tabs and will rob the 2 hub nuts off the old truck. Quote Link to comment Share on other sites More sharing options...
western Posted May 21, 2010 Share Posted May 21, 2010 Feel a bit lost without a parts cat at the moment 110 1987 on parts book, might help, till you get Microcat sorted for the Td5 differences Quote Link to comment Share on other sites More sharing options...
