landy V8 Posted May 23, 2010 Share Posted May 23, 2010 Hi All As the decription says really.Can i fit a Td5 loom into my Tdi 90 bulkhead. I'm after a new loom as mine is a little suspect and some of the stuff doesn't work.i mainly need it for the lights and dash instruments,as i only need oil pressure/temp and water temp but they're going to seperate gauges.I've got a V8 with carb so no electrics needed. Just thought i could replace it with this one as i can get a new one for about £100. Cheers Ralph Quote Link to comment Share on other sites More sharing options...
Dave W Posted May 23, 2010 Share Posted May 23, 2010 To make the job easier you could out a TD5 dash in, other than that (and needing somewhere to put the under seat fuse box) you'll need to make up a harness for the heater motor at both ends (connectors are different on a TD5). You'll need to buy a couple of wing harnesses and you'll either need to replace the chassis harness of graft the 300TDi connectors onto the TD5 loom. The bulkhead on a TD5 is different, you may need to modify yours to get the loom through the bulkhead although you may be able to use the existing holes. When I did mine I wanted to leave the TD5 loom available should I ever need/want to fit a TD5 in to replace the V8/LPG, if you took a more "damaging" approach and just hack away at the TD5 loom you can probably simplify things a bit. I bought a sacrificial TD5 engine loom and adapted that for the V8 so that everything just plugged in to the TD5 bulkhead loom. It's a lot of work although in the long term I'd say the TD5 loom is a better loom than the 300TDi, it's great to be able to remove a wing without having to disconnect all the wires, for instance. If, however, you want to leave your dash as it is and don't fancy spending a few days tracing and linking through the circuits that the immobiliser/alarm and the TD5 ECU are expected to link up, you're probably best trying to get a 300TDi loom. Quote Link to comment Share on other sites More sharing options...
landy V8 Posted May 23, 2010 Author Share Posted May 23, 2010 I don't want to have to modify the bulkhead as it's just been painted.It is a Tdi loom in already but it's been spliced about a bit and i'm useless with wiring diagrams so i'm unsure what goes where.didn't want to have to go to Autospark as they're about £300 for a loom.Just thought a Td5 loom would fit without any need to cut the bulkhead about. would this fit into a Rhd 90 ebay item 12057261156 could i just turn it round Quote Link to comment Share on other sites More sharing options...
Dave W Posted May 23, 2010 Share Posted May 23, 2010 Can't find that item number ? If you don't want to spend a lot of time with wiring diagrams and splicing looms together then the TD5 loom isn't an option. A LHD 300 loom will kind of fit but, again, will need to be modified. The feeds to the wings (indicators especially) will need to be swapped around and I have a feeling the chassis loom connectors are on the same side on a LHD as they are on a RHD so if you simply turn the loom over you'll have to sort that out too which may not be an easy job. Perhaps someone with a LHD could confirm that either way. Quote Link to comment Share on other sites More sharing options...
