Frogland Posted May 28, 2010 Share Posted May 28, 2010 There are oily traces around the turbo to intercooler elbow area and the bottom intercooler hose.The hoses are in good condition.They pressurize.There's no play in the turbo.I don't have a boost gauge,i'm concerned that oil may be finding it's way into the boost pipe .Is this oil coming from the crankcase breather ? ,the main air inlet doesen't appear particularly oily. -Bog standard 110 300tdi 1998 Quote Link to comment Share on other sites More sharing options...
ibexman Posted May 28, 2010 Share Posted May 28, 2010 I had a 300 for 5 years and always found oily pipes never had any effect on engine at all just clean now and again cheers chris Quote Link to comment Share on other sites More sharing options...
Frogland Posted May 28, 2010 Author Share Posted May 28, 2010 Thanks, how could i check that boost to IP pipe ? Quote Link to comment Share on other sites More sharing options...
ibexman Posted May 28, 2010 Share Posted May 28, 2010 check your air filter too i always used to fill to low dipstick mark and check often cheers chris Quote Link to comment Share on other sites More sharing options...
Adam001 Posted May 28, 2010 Share Posted May 28, 2010 Sounds relatively normal, the turbo compressor shaft floats on oil bearings so some oil is expected to leak through. So long as you do not have blue smoke while the engine is running you shouldn't need to worry Adam Quote Link to comment Share on other sites More sharing options...
