siearl Posted May 28, 2010 Share Posted May 28, 2010 Hi all, I have a 98 3dr 1.8 petrol freelander. Recently i had a need to use my spare keys and remote, the remote wouldnt work so i changed the battery and still nothing, is there something i should be doing and not or does it look like i am going to have to get it programmed at specialist. Cheers Si Quote Link to comment Share on other sites More sharing options...
FreebieFreddy Posted May 29, 2010 Share Posted May 29, 2010 If the remote worked in the past on your vehicle ..... (with a new battery) it should work now. It doesn't need re-programming because you haven't used it for a while. Another problem is ...... the switches tend to come away from the circuit board. Open the remote and check the 4 'legs' of the switch are soldered down. edit: also check the length of the switch (the plastic bit that the rubber cover presses down, I have known these to break. Quote Link to comment Share on other sites More sharing options...
dubtike Posted May 30, 2010 Share Posted May 30, 2010 keep pressing the lock/unlock buttons a few times while standing close to the drivers door and front wing. when the battery is changed, it needs to reset itself to the system Quote Link to comment Share on other sites More sharing options...
