Carl R Posted June 2, 2010 Share Posted June 2, 2010 Sometimes when i turn key on ignition dash lights are dim turn ignition off then back on all lights up ok? Also sometimes when i put indicators on i get a buzzing noise rev counter drops and mileage goes off. It also starts to missfire before it starts playing up. Any ideas please. Checked battery ok relay on indicators ok Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2010 Share Posted June 2, 2010 Remove battery leads,clean the batt posts & clamps,smear some vaseline on the battery posts & refit the cables, remove & clean & refit the main earth cables too. Quote Link to comment Share on other sites More sharing options...
FreebieFreddy Posted June 2, 2010 Share Posted June 2, 2010 When the engine is running the battery does not matter. So check the dashboard earthing point (where all the black wire go) on the bulkhead, behind the binicale. Quote Link to comment Share on other sites More sharing options...
Carl R Posted June 5, 2010 Author Share Posted June 5, 2010 Thanks for suggestions checked all earths all ok still doing same so i removed ignition switch and mutiplug gave them a squirt of wd40 and its been fine ever since. Cheers again. Quote Link to comment Share on other sites More sharing options...
