heater problems p38 dt
Mr Alford
get the ecu read for faults proberly blend motors do the heater orings while you are there as well as it is stripped out for the same job time wise can all be done 5 hours you will need to get the blend motors recalibrated after fitting don't bother with second hand been there 5 times for one guy and still he buys used units with what it has cosat him gen new ones and he would be quids in!
