chrisoleary Posted June 8, 2010 Share Posted June 8, 2010 What sealant do you people use for fitting the rear window in the door. I have a new one to fit and the lumps left from the welds looks like it might cause a problem if I don't fit it with enough sealant. Quote Link to comment Share on other sites More sharing options...
jbs Posted June 8, 2010 Share Posted June 8, 2010 My 90's rear door glass is sealed in with sikaflex(sic) and I then put the aluminium strips back in place with the self tappers that came out of it-It's been there for at least 6 months and hasn't moved at all, Can't remember where I got it from now either have a look on the net and google it that should give you an answer and an adult will be along in a mo to either agree with me or tell you what you should be using HTH John Quote Link to comment Share on other sites More sharing options...
Guest Posted June 8, 2010 Share Posted June 8, 2010 Have a drive around and find a mobile window fitter, bung them a fiver and get some of the glass sealant they use..... Quote Link to comment Share on other sites More sharing options...
kingrat Posted June 8, 2010 Share Posted June 8, 2010 TigerSeal £5 per sealant tube. My rear window is 4mm Ali plate and even that does not leak or rattle Quote Link to comment Share on other sites More sharing options...
