sharpy Posted July 10, 2010 Share Posted July 10, 2010 Hi all, could anyone tell me the part number for the spring that sits under the top plate on a disco fuel pump where i believe you can tweak your engine as i have a performance one in there and want a normal one. Cheers Paul Quote Link to comment Share on other sites More sharing options...
disco_al Posted July 10, 2010 Share Posted July 10, 2010 performance one? the spring that sits under the top cover (the one held on with 4 bolts) isn't available separately from landrover. you may potentially get one from a bosch injection specialist though. there is (AFAIK) no performance version available, i expect someone in the past has done the pump tweek, in which case it would need to have the procedure reversed, or if they did it right, there should be a mark to reset the diaphragm to. Quote Link to comment Share on other sites More sharing options...
western Posted July 10, 2010 Share Posted July 10, 2010 As above, Bosch diesel injection agent for that, doubt it's been changed, most likely adjusted to give the extra oomph. Quote Link to comment Share on other sites More sharing options...
sharpy Posted July 12, 2010 Author Share Posted July 12, 2010 I dont know, all the guy at the garage said was that the spring in there now is blue, and it shouldnt be?, he has also said that he has adjusted it to the max to reduce performance and it wont go any further because the size of the spring. Paul Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2010 Share Posted July 12, 2010 Find your nearest Bosch diesel injection place & ask them, I haven't touched my tdi's FIP, so no idea if the spring is colour coded or not. Quote Link to comment Share on other sites More sharing options...
