craig Posted July 13, 2010 Share Posted July 13, 2010 are the brackets that are welded on the chassis that hold the rubber engine mounts on a 300 tdi flush with the top of the chasis like on a disco or are they lower down the chasis rail? i have cut off the old mounts on the 110( nissan straight 6) and need to make up new, easiest way seems to make up some plates attach to rubber mounts and lower engine into place, tack in place ,remove engine and strenghten mounts.... sorted??? hope this makes sense??? craig Quote Link to comment Share on other sites More sharing options...
jad Posted July 13, 2010 Share Posted July 13, 2010 Defender 300 is the 2nd from left. Think the best solution is to as you have said bolt the engine up to the bell housing and then tack the mounts in place. remove and weld properly Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted July 15, 2010 Share Posted July 15, 2010 according to the manual they need to be fitted with a minor angle. I fitted mine with this angle. Quote Link to comment Share on other sites More sharing options...
