Roverbo Posted July 14, 2010 Share Posted July 14, 2010 Hi, I´ve got a 1990 RRC with the Wabco ABS system. For about a year ago, the abs pump started running at shorter and shorter intervals, down to every 1 minute, and I changed the Nitrogen-charged Accumolator to a new one (bought from Britishparts). Everything then worked fine, I could accept the pump now running every 5-7 minutes. But now everythings seems to be "as before". Yesterday I tracked a interval at 1 min. 40 sec. (without applying the brake pedal at all). Could it be the "new" accu allready has leaked the pressure out, or did I buy a piece with 10 years on the shelf, "almost done" at the day I got it? The pump and relays etc. seems to be OK, from start the pump runs 40 secs to charge up, as stated in the RAVE manual. BR Bo Helsted Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted July 15, 2010 Share Posted July 15, 2010 You might have a leaking brake line? Quote Link to comment Share on other sites More sharing options...
Roverbo Posted July 15, 2010 Author Share Posted July 15, 2010 Hmmm...Wouldn´t I see some brake fluid dripping somewhere ? And the level in the reservoir drop? /Bo Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted July 16, 2010 Share Posted July 16, 2010 Possibly - but I suspect a corroded line could let air in before it's bad enough to let brake fluid out. What do others think? Am I talking rubbish? Quote Link to comment Share on other sites More sharing options...
Roverbo Posted July 16, 2010 Author Share Posted July 16, 2010 Hi Geoff, this is a drawing of the high/low pressure system. The thick, black lines shows the high pressure parts (Valve block, pump, accumolator, mastercylinder, lines, calibers). I could understand if the pump would run often if a brake line was corroded/leaking - IF i pushed the pedal. But its like the high pressure system looses pressure even though i´m just idling without using the brakes. No pressure is reliefed from the pump/accu parts. Lack of Nitrogen ("biased" pressure) in the accu would make the pump run more in case if deep brakings, I understand this (less energy would be accumolated). This has always been a small mystery to me (well, many parts of my rangie is...), even when the pump only had the pleasant 5-7 minute intervals. Anyone who can explain ? Cheers Bo Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted July 19, 2010 Share Posted July 19, 2010 That probably shoots my theory down then. Quote Link to comment Share on other sites More sharing options...
