defender-kris Posted July 20, 2010 Share Posted July 20, 2010 i have got a Defender and i have put a disco 200tdi engine in it and the Temp gauge go s on to the edge of the red when been running for a bit is this because the disco gauge runs cooler ?????? Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2010 Share Posted July 20, 2010 because the Disco sender & Defender temp gauge don't work well together, ou can fit the sender fom your old engine into the Disco 200Tdi.as this worked with the existing gauge in the old engine, it should contain to work in the new engine, the sender/wiring/gauge don't know what engine they are fitted to. this is a very common problem with this engine swap, lots of info in this forum about it. Quote Link to comment Share on other sites More sharing options...
Ian J Posted July 20, 2010 Share Posted July 20, 2010 There are apparently two different threads - so you might find your old sender won't fit in the Disco engine. Steve Parker sells new senders with both thread sizes which can be used if this is the case. I forgot to take the old sender off my engine before it got taken away, so it's on my "to do" list! Ian. Quote Link to comment Share on other sites More sharing options...
kieron333 Posted December 27, 2010 Share Posted December 27, 2010 Hi, i have the same problem. Does the above advice mean that a 2.5 petrol sender (the original engine) will work for the 200 tdi? Quote Link to comment Share on other sites More sharing options...
western Posted December 27, 2010 Share Posted December 27, 2010 Hi, i have the same problem. Does the above advice mean that a 2.5 petrol sender (the original engine) will work for the 200 tdi? Yes, it should be possible to transfer the original temp sender on to the Tdi. Quote Link to comment Share on other sites More sharing options...
