peter deer Posted July 24, 2010 Share Posted July 24, 2010 Hi Strange : the front electric windows work fine all the time but the rear ones occasionally don't work (either from the centre control panel or from the door panel switch) However,if ,i switch the front ones first on and off ,then the rear ones will work what could the problem be ,you think? Peter Quote Link to comment Share on other sites More sharing options...
peter deer Posted July 24, 2010 Author Share Posted July 24, 2010 hi again I should have mentionned :this is a 1995 , 2.5l diesel Discovery peter Quote Link to comment Share on other sites More sharing options...
ches Posted July 24, 2010 Share Posted July 24, 2010 this may help. http://www.discoweb.org/window/index.htm Quote Link to comment Share on other sites More sharing options...
peter deer Posted July 25, 2010 Author Share Posted July 25, 2010 Many thanks Ches I would never have thought of something like that !! i'll have a little look peter Quote Link to comment Share on other sites More sharing options...
GERTRUDE-M Posted July 28, 2010 Share Posted July 28, 2010 this may help. http://www.discoweb.org/window/index.htm Brill! Thanks for that, I too have problems with the rear windows on my 1998 300; they work when they want to and sometimes fail open which is a nuisance. The vendor garage is looking for a replacement board [not sure I know which] under warranty. I will post a new request about intermittent wiper behaviour too. Quote Link to comment Share on other sites More sharing options...
mayur Posted July 29, 2010 Share Posted July 29, 2010 iv had problem with my driverside rear door window turns out it was the switch on the center consol which is broken but when its not pluged in you cant open/close the windows from the rear switch :S Quote Link to comment Share on other sites More sharing options...
