David_LLAMA4x4 Posted July 29, 2010 Share Posted July 29, 2010 Sorry for this as it will I am sure be seen by some as an advert / spam / crime / etc. BUT How much? I am referring to the ARB heavy duty airline kit that seems to be £49.50 + vat I have just finished adding up the cost of all the bits to make one of these kits using stainless braid hose and it is way cheaper than the manky big black rubber thing available. A whole kit including the little fitting to go onto the ARB fitting in the diff case, the same length of hose and a converter back to 5mm push-in pipe at the chassis end along with a mounting bracket and self tapping bolt ( so basically everything you get in the ARB one ) works out to £35+vat That saves £17 and you are buying what could be described as a better quality kit David Quote Link to comment Share on other sites More sharing options...
headhunter Posted July 29, 2010 Share Posted July 29, 2010 David Is that what it costs or what it costs to buy from you? John Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted July 29, 2010 Author Share Posted July 29, 2010 David Is that what it costs or what it costs to buy from you? John That is the price you can buy one from me for David Quote Link to comment Share on other sites More sharing options...
landmannnn Posted July 29, 2010 Share Posted July 29, 2010 David,is that per diff? ie do I need 2 kits, one front and one rear? Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted July 30, 2010 Author Share Posted July 30, 2010 David,is that per diff? ie do I need 2 kits, one front and one rear? That is per axle!! Which makes the £50+vat from ARB twice as painful David Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted July 30, 2010 Share Posted July 30, 2010 Hi, Are you looking into the airline kit to pump up your tyres as well to see if it is cheaper than ARB? Steve Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted July 30, 2010 Author Share Posted July 30, 2010 Hi, Are you looking into the airline kit to pump up your tyres as well to see if it is cheaper than ARB? Steve I will have a look - I assume it is just a tyre inflator and a hose with an appropriate adaptor for the compressor.... I will report back David Quote Link to comment Share on other sites More sharing options...
