Wabco ABS diagnostic problems
Adam001
Hey,
I have come to the point where I have become defeated by the ABS on this car I am working on and could really use some help :)
Typical story, ABS light always on, after a long time hunting through the internet I managed to find out how to get the ABS light to flash the codes
few details on the car
1994 300tdi Discovery
Wabco ABS ECU - Part number AMR1097 446 044 040 0
diagnostic is taken from the vehicle diagnostic plug not a standalone ABS diagnostic plug
The warning light relay matches the description (wiring colours) of the older Lucas system that uses the standalone plug not that of the vehicle diagnostic plug :unsure:
I do not understand why it seems to have the wiring types from both systems, however the jumper test does work...kind of...
Following the online guides the ABS system spits out code 2-1 constantly no matter how many times I attempt it (50+ I wouldn't like to think how many times this code has repeated ) and this code does not appear anywhere on the guides, the closest I have found is in the link below, but the ecu doesn't match :unsure:
http://www.abstroubleshooting.com/abs-troubleshooting-step-4/blink-code-listings/wabco/d-version-ecu-blink-codes.html
Anyone else had this? Really not sure where to go from here, is there a way to 'clear all'!
Adam
Yes I am 100% sure it is code 2-1 assuming that the 2.5 sec flash followed by the 0.5 flash is the start sequence. As I know some ABS ECU only have a single flash start sequence. But neither 2-1 or 1-2-1 appear on any land rover blink code sheets.
So is that a certainty that the ECU has gone?
Thanks
Adam
Hi , Try this link to a 31 page maintrenance manual from Wabco
www.meritorhvs.com/MeritorHVS_Documents/mm38.pdf
If in doubt find a local LR specialist with a good diagnostic tool. Second hand spares are available but make sure you do not buy second hand trouble . Try and use a specialist who has access to second hand parts and make sure he checks it out on your Disco before paying for it. Regards Jonathan
Not sure if my previous post worked so Try this link to a 38 page maintenance manual
Regards Jonathan
You sir are an absolute star, that manual is very useful :) we will be able to get a new ECU during the week
Does anyone know what type of lamp i need to get before i rip the dash out??
Thanks
Dave
If you have a haynes manual it should say in there which type, halfords little flip book things will probably list it aswell
