Ferrett Posted August 3, 2010 Share Posted August 3, 2010 Hi. This is my first post so please bear with me. I am just starting on the journey of replacing the cross-member on my 90 TD5 2001MY. I bought a new CM last year and it has sat in the garage still packaged whilst I talked a lot about the change and done even less. Now I have un-wrapped it I am disappointed with the quality (like many other posters on hear) and intend to blank as much as possible just like the Les Henson article and photos (fantastic post). However, I have just discovered that the mounting points for the fuel tank are different on the existing CM compared to the new one, so I think I have bought a CM for a 300TDi rather than a TD5, not so much of a problem as I can always drill and tube some mounting holes to suit. But what else is different? Am I wasting my time and should I buy the correct cross-member? Any one that can help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Ferrett Posted August 3, 2010 Author Share Posted August 3, 2010 no chance of returning it? td5 has different tabs to mount the tub on i believe No chance. Purchased 11 months ago. My fault should have unpacked and checked it when I bought it. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 3, 2010 Share Posted August 3, 2010 300 doesnt have a rear mounted tank, so it wont have any tank mounts on it at all... Quote Link to comment Share on other sites More sharing options...
Ferrett Posted August 3, 2010 Author Share Posted August 3, 2010 Does a 110 have a rear mounted tank.....if so may have a cross-member for one of those? Things are getting better and better Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 3, 2010 Share Posted August 3, 2010 ye 110's do, and afaik its different to 90's, squarer from the pics i've seen. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 3, 2010 Share Posted August 3, 2010 You'll need to clear the flange in the centre section of inside face of the x-member as it fouls the tank and you will find that any bolts from towing apparatus will also foul the tank as the 300 bolts right through the x-member. I'd stick it in the for sale section and buy the proper x-member but then, that's not as much fun is it ? Mo Quote Link to comment Share on other sites More sharing options...
