slm Posted August 3, 2010 Share Posted August 3, 2010 i turn the ignition key but fuel pump doesn't run. if i put a direct live to pump it runs. if i push in flap in air flow meter when ignition on fuel pump runs. i replaced engine with a complete engine from a running rangie. this included everything ecu loom the lot. it turns over but won't fire. i have swapped ecu dissy coil relays from old engine and back again. when pump is running you can hear fuel flowing.any ideas would be great thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 3, 2010 Share Posted August 3, 2010 Full flapper & hotwire diagnostics in the technical archive, the behaviour of the fuel pump is correct, it will not run until there is some airflow from the engine turning. #1 simple fault is the ECU not seeing the signal from the coil -ve, again it will not fire the injectors until it sees pulses from the coil as the ignition fires - check the wiring from coil -ve to ECU, if that doesn't work then go through the diagnostics manual. Quote Link to comment Share on other sites More sharing options...
teslo Posted August 4, 2010 Share Posted August 4, 2010 check if you have spark and engine is not flooded. Quote Link to comment Share on other sites More sharing options...
slm Posted August 4, 2010 Author Share Posted August 4, 2010 i will check your suggestions but on all my previous rangerovers when you turn the ignition key to 2nd position you can hear the fuel pump running as though pressurizing the system up. as pressure is reached it then stops. this is why i am concerned as no noise from pump. when i turn engine over pump doesn't run while cranking. any more advice would be great but i will try whats been suggested .thankyou for your help Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 4, 2010 Share Posted August 4, 2010 Later hotwire type I think do run the pump for a quick priming pulse before you start the car, but flapper does not. It should run once the engine is drawing enough air to open the flap. Check you have sparks, and check the coil -ve has connectivity back to the ECU TACH pin. Quote Link to comment Share on other sites More sharing options...
slm Posted August 4, 2010 Author Share Posted August 4, 2010 printing off data from tech files so will have a play at weekend hopefully thanks for your help. Quote Link to comment Share on other sites More sharing options...
