carlosbeldia Posted August 4, 2010 Share Posted August 4, 2010 Hi there. I'm working in a Castrol import company, so I have the option for buying BOT 402 MTF instead of Texaco MTF 94. However, reviewing technical sheet for both of them, I find they are really differents, but I don't know how to read their values, can anybody help me with this? Texaco MTF94: http://www.texaco.es/es/ps/pdf/MTF-94.pdf Castrol BOT 402: http://www.castrol.com/liveassets/bp_internet/castrol/castrol_south_africa/STAGING/local_assets/downloads/t/BOT_402_TDS.pdf Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 4, 2010 Share Posted August 4, 2010 The castrol oil appears to have a much higher viscosity (thickness) when cold, and a slightly higher viscosity when hot. I'd imagine it would probably cause shift issues. Apparently Castrol SMX 75w80 is a better match for MTF94 edit: having said that, it seems the castrol oil (Actually called SMX-S) is a 75w85 and is still a bit thicker when cold than the proper oil. Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted August 4, 2010 Author Share Posted August 4, 2010 So I better stick with MTF94...... right? Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted August 4, 2010 Share Posted August 4, 2010 I use SMX-S in my Disco's box (LT77) and have found it to be a vast improvemant over ATF, none of the notchy changes that were there on ATF when cold. Quote Link to comment Share on other sites More sharing options...
jbs Posted August 5, 2010 Share Posted August 5, 2010 And I use MT75 in my main gear box-horses for courses John Quote Link to comment Share on other sites More sharing options...
