Gilslandy Posted August 10, 2010 Share Posted August 10, 2010 Hi guys, I'm thinking of fitting plus 5 inch shocks to the front of my 90. i have standard height turrets and standard ranga rover coils with a 2 inch spacer under the coil. Will the new shocks fit and work well with my present setup? Thanks alot Gil Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted August 10, 2010 Author Share Posted August 10, 2010 + 2" turrets required. some sort of spring re locator. take a look at llama 4x4 / gwyn lewis to see there kits and some extended brake lines thanks, ok i have extended brake pipes already (plus 4 inch). so i need turrets 2 inches longer then the standard ones? re relocatoers ok, thought abt that. my main issue was the turret height so as not to bottom the shocks. thanks Quote Link to comment Share on other sites More sharing options...
landmannnn Posted August 10, 2010 Share Posted August 10, 2010 Not sure understand why +5" dampers and +2" turrets would be better than +3" dampers with standard turrets? Surely the articulation would be the same. Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted August 10, 2010 Author Share Posted August 10, 2010 Not sure understand why +5" dampers and +2" turrets would be better than +3" dampers with standard turrets? Surely the articulation would be the same. in theory yes, but i never saw plus 3 shocks. that would be ideal! Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 10, 2010 Share Posted August 10, 2010 Why? Because you get an extra 2" of compression travel .... ? Quote Link to comment Share on other sites More sharing options...
