Jon W Posted August 10, 2010 Share Posted August 10, 2010 Been to look at a discovery I am thinking of buying. All seems ok, only gripe is the gear box is notchy, and when going for 1st your end up in reverse. Like wise trying to locate the other gears as to where they should be. So can this be adjusted relatively easily with the gearbox in situ?? Answers very much appreciated asap as need to tell the guy whether I want it or not. Jon Quote Link to comment Share on other sites More sharing options...
ches Posted August 10, 2010 Share Posted August 10, 2010 does the gear lever self center opposite 3rd and 4th when in neutral? Quote Link to comment Share on other sites More sharing options...
Jon W Posted August 10, 2010 Author Share Posted August 10, 2010 Erm not entirely sure. Reverse doesn't seem very far over to the left, like it should be, so when going for 1st you get reverse. 5th is very far over to the right, so it seems like the gates need moving over if that makes any sense?? Cheers Jon Quote Link to comment Share on other sites More sharing options...
Jon W Posted August 10, 2010 Author Share Posted August 10, 2010 Have used the search function and found the answer now. Should have done to begin with really. Looks like i will be a discovery owner soon then! Quote Link to comment Share on other sites More sharing options...
Paul 200 TDI Posted August 11, 2010 Share Posted August 11, 2010 I think you just got to get used to it, I was the same with mine at first, Sabine still is unsure about 1st or reverse. it could however be the bias plate or springs, both easy to replace Quote Link to comment Share on other sites More sharing options...
