henk Posted August 13, 2010 Share Posted August 13, 2010 I installed longer shackles at the front of my SWB but it looks if the front propshaft is at his maximum length (62,5cm) so I have some questions: 1. Would a defender propshaft fit and if yes which one? 2. What about putting a 15mm spacer between the transfercase and the propshaft? Extra advantage is that propshaft would hit chassis 'later'. Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 13, 2010 Share Posted August 13, 2010 You're into custom high angle propshafts I'm afraid - nothing off the shelf will fit. I'd shy away from spacers, as what you really need on the front of a series is a longer propshaft, no a shorter one, as the U/J's bind up otherwise as it runs at too much of an angle. You have also corrected the castor angle I take it if you've fitted longer shackles, and made sure that your brake hoses are long enough? Jon Quote Link to comment Share on other sites More sharing options...
henk Posted August 13, 2010 Author Share Posted August 13, 2010 Length of the hoses will be tested next week Maybe I can adapt a double cardan of a 90 to fit Quote Link to comment Share on other sites More sharing options...
